Author: Subject: Exhaust question!
Sebastian
posted on 7/6/10 at 06:54 PM Reply With Quote
Exhaust question!
After driving this weekend with my Tiger i really need to bring the noise down, i have a 2ltr Zetec wih TB's and using the original exhaust manifold with 1 pipe to the side and have the silencer directly behind it, so no cat fitted since i don't need it for the MOT here in Holland so i have the following questions:
- Will a big bike silencer of a chopper or big v-twin do the trick?
- Will a catalyc converter help reduce the noice.
- And if you don't have a lambdasensor fitted will a Catalyc converter then help bringing the emission down?
What's your advice regards this point, bigger and longer silencer or.......
snapper
posted on 7/6/10 at 07:22 PM Reply With Quote
So many questions, so i will only give you my opinion...
A big bike silencer will probably not help.
A Cat will reduce the noise and the performance.
A cat and a lamda will only reduce emmisons if you have fuel injection setup with an ECU.
Bigger and longer silencer will make the most difference and won't restrictBHP that must.
[Edited on 7/6/10 by snapper]
I eat to survive
I drink to forget
posted on 7/6/10 at 07:32 PM Reply With Quote
I think I would agree Some bike cans are actually quite noisy and although sounding nice might not help the situation.
A cat will swallow power and (without a lambda / ECU combo) will be short lived in all likelyhood unless your tuning happens to be spot on.
Is your exhaust packable? You could try that.
Sebastian
posted on 7/6/10 at 07:55 PM Reply With Quote
OK so a longer an bigger silencer should do the trick, is a 6" silencer a good way to go?
I think it's packable what is the best material to use then?
whitestu
posted on 7/6/10 at 07:59 PM Reply With Quote
Standard R1 cans are fairly quiet. I have one on my Zetec and was under 90db when measured for a track day.
Stu
matt_gsxr
posted on 7/6/10 at 09:03 PM Reply With Quote
What are your noise and emission requirements?
Where are you at the moment?
I have a MK built 6inch stainless exhaust, cost £150 and my bike engine is down to 95dB at 7000rpm (possibly slightly higher now I have different cams), which is very inoffensive.
You could fit a turbo, as these muffle the exhaust noise too!
Matt
paulf
posted on 7/6/10 at 09:35 PM Reply With Quote
My car is also rather noisy but most of the noise is induction roar when driving fast.Maybe an air box would help.
Paul.
DRC INDY 7
posted on 7/6/10 at 09:54 PM Reply With Quote
A cat fitted will bring the emissions down with carbs fitted but not as much as a fuel injected one
cars used to have unregulated cats fitted in the days gone by
ie lada and nissan micra imports had cats carbs and even contact breaker system
Puddle Dodgers Club
