Dave Bailey
| posted on 9/6/10 at 07:41 PM |
Steering Rack extensions
Just some advice of what is considered to be the correct way to fit the extensions.. With a two lock nuts as in the the first picture or the second
with a single lock nut...
  Steering Rack extension 1
  Steering Rack extension 2
Dave B
Andybarbet
| posted on 9/6/10 at 07:45 PM |
I reckon the 2nd picture, butted/tightened up to the track rod end & with the lock nut on the steering rack end.
That is what i am planning on doing, just my opinion though
Johneturbo
single as per second pic
ETA also having the second nut would mean less thread in the track rod end
[Edited on 9/6/10 by Johneturbo]
Davg
| posted on 9/6/10 at 07:49 PM |
Ditto as above. Stick a dab of locktite on the track rod end to extn if you like as well.
cheers D
bigrich
| posted on 9/6/10 at 07:50 PM |
deffinately picture 2
| posted on 9/6/10 at 07:52 PM |
Yep, 2nd picture. Why add an extra nut? It just increases the weight............
Phil
gavin174
| posted on 9/6/10 at 08:06 PM |
yeah i agree pic 2...
have you deliberately fitted shocks the wrong way round to keep adjuster out of the way..
Dave Bailey
| posted on 9/6/10 at 08:22 PM |
Thanks guys...
In answer to your question about the shocks.... yes I have deliberately mounted the shocks this way.. The build manual for the car states this is the
correct way...
thanks...
Dave B
Davg
| posted on 9/6/10 at 08:32 PM |
''build manual ''
= B M
= Bin Material
40inches
| posted on 9/6/10 at 08:42 PM |
2nd one also, but there has been one IVA failure because the examiner wanted pic 1 I have done as pic 2 but drilled a 4mm hole in the join and
filled with weld, with photo as evidence.
