smart51
| posted on 11/6/10 at 03:00 PM |
How do I take apart CV joints?
I have 2 drive shafts from my FWD donor and want to split them at the outer CV joint so I can use the ends to clamp the hub to the upright. They
don't just pull apart and poking them with a stick hasn't given me any bright ideas. How do I separate them without resorting to the
angle grinder?
iank
| posted on 11/6/10 at 03:13 PM |
If you remove the CV boot you should find a retaining circlip.
If you want the chapter from the factory manual (Seicento but I believe them to be identical) drop me a u2u with your email.
Anonymous
