alistairolsen
posted on 21/6/10 at 12:32 PM |
Brake line brackets
Where you terminate the hard line and join to the flexi lines, on tintops there is normally a bracket and a spring clip... What do people normally do
on locosts and the like? I dont overly fancy filing 4 out of 2mm sheet tbh!
My Build Thread
40inches
posted on 21/6/10 at 12:35 PM |
Ally angle
Flexy bracket
big-vee-twin
posted on 21/6/10 at 03:43 PM |
I use 2mm ali strip 20mm wide from B&Q costs a few pounds, cut bend drill fit see below
Rear caliper conversion
http://www.triangleltd.com
