scoop
| posted on 30/6/10 at 08:29 AM |
Loose steering column help
Got a sierra steering column which keeps working its way loose at the point that it goes through the bulkhead. Ive got the proper sierra bits fitted
at that point. Ive tried the tie wrap thing but it still happens!
Any ideas?
| posted on 30/6/10 at 08:45 AM |
I used jubilee clips to hold the column into the bush. One either side. Works well
Wheels244
| posted on 30/6/10 at 08:57 AM |
I drilled the column and put a roll pin next to the bush -it will only come out now if I want it to.
james h
| posted on 30/6/10 at 11:28 AM |
I used a bearing setup after I got the same problem as you. It is much smoother and there is no play whatsoever. I think the bearing itself cost £10
or so. If you do a search on here, I think it should come up - I think several people on here have done a similar thing.
ETA Linky dink
James
[Edited on 30/6/10 by james h]
dlatch
| posted on 30/6/10 at 11:32 AM |
from advice on here i did this
  steering bearing
works a treat
snapper
| posted on 30/6/10 at 05:19 PM |
As the post just above this ^ I did the same on advise from the North West Hoodies forum, it's from Revolution bearings and theonly mod is to
sand down the Sierra plastic bit to fit in , it works very well
I eat to survive
I drink to forget
scoop
| posted on 2/7/10 at 02:45 PM |
Many thanks for replies. Sorry for late reply just been work and kids this week!
Will start with the jubilee clips either side, just 'cos ive got them in the garage, and go from there.
Thanks again.
