dilley
| posted on 10/7/10 at 10:36 PM |
drive shaft angle
Hi Guys,
I am trying to do a mock up of a bike engine and a chain drive diff in my buggy and its bloody tight!!!
Is there any reason why I cannot move the diff back and run the drive shafts not at 90 degrees to the wheels??
drive shafts move up and down so why not foward or backward fixed/mounted???
hope tis makes sense!!
NigeEss
| posted on 10/7/10 at 10:39 PM |
If it's only a few degrees it is actually beneficial as it spreads the wear a bit more
rather than a constant load at one part of the CV.
mangogrooveworkshop
| posted on 10/7/10 at 11:02 PM |
as long as you are still in the working envelope of the cv you will be ok. Dont exceed the angles other wise they blow up
Madinventions
| posted on 10/7/10 at 11:04 PM |
Should be fine - just don't go for huge angles! I've been running my driveshafts at about 8-10 degrees now for a few hundred miles
without any problems.
Ed.
View my band website:
http://www.shadowlight.org.uk
RazMan
| posted on 10/7/10 at 11:49 PM |
Mine are at ~5 degrees with no problems in 3 years.
I had some teething problems with the CV boots exploding due to the angles caused by strapping the car down on the rollers - I think the grease was
thrown to one side and the centrifugal force made it burst through the boots .....twice! All this happened at a roller speed of 150mph
This was cured by using a race quality CV boot which doesn't flop about like the cheapies. You can see the difference in this pic.
Raz
dilley
| posted on 11/7/10 at 06:52 AM |
Where can they be purchased Raz???
RazMan
| posted on 11/7/10 at 09:40 AM |
I knew you were going to ask me that
Its the GKN Fast Boot here
http://www.merlinmotorsport.co.uk/GKN-CV-JOINTS-CV-Joints/c295_296/index.html
[Edited on 11-7-10 by RazMan]
Raz
turbodisplay
| posted on 11/7/10 at 10:03 AM |
At the risk of a hijack, mine have 11 degress is that too much? Or will it just wear quicker.
Obviously fwd car operate huge angles at the outer cv joint, and under power.
Darren
