Author: Subject: what poundage front dampers for inboard suspension
Johneturbo
posted on 12/7/10 at 03:19 PM Reply With Quote
Just after some ideas
I had my cars supsension all set up @ procomp a few weeks ago... great sevice very thorough and was nice to meet Matt and Ivan.
now on the dyno for the dampers they were roughly the same about 85lbs on lowest settings front and back
the back dampers are direct angle, but the fronts are via rocker/pushrod so would have a ratio?
i did speak with protech they can do a revalve but what would be a good starting point?
just after some advice
[Edited on 12/7/10 by Johneturbo]
Danozeman
posted on 12/7/10 at 03:48 PM Reply With Quote
Would procomp not be the best people to speak to?
Dan
Johneturbo
posted on 12/7/10 at 03:51 PM Reply With Quote
I have.. he did mention paul aka paublo999
but he didn't know what poundage the front dampers were when he got them revalved.
i can also understand matt not wanting to give out information as i think he spent money and time on it
so here i am!
Frosty
posted on 12/7/10 at 04:21 PM Reply With Quote
Unfortunately the question cannot be answered on a forum since the motion ration must be known to know what effect it will have on the wheel (unless of course someone else has the exact same setup and are using the same rocker positions on their car).
I'd head back to Procomp and have them measure the ratio for you as it's pretty tricky, and then you can pick a base spring and damper setting from there.
If you want to measure it yourself then I can tell you how. To save you the bother though, Procomp will no-doube be able to recommend a good starting point anyway for that car.
paublo999
posted on 12/7/10 at 04:23 PM Reply With Quote
I used 160 but tried 200's last weekend on old tyres. Revalved I use one click on my protechs, 4 on the rears. 150 springs on the rear.
Just shout if you have any q's
[Edited on 12/7/10 by paublo999]
My videos http://www.youtube.com/user/ninjabogeyracing
bi22le
posted on 12/7/10 at 05:13 PM Reply With Quote
Can you not speak to MNR? They must offer a standard set-up surly.
Please read my ring story:
Johneturbo
posted on 12/7/10 at 05:35 PM Reply With Quote
Paul, did you get all four dampers revalved? matt fitted 125lbs springs on the front to get bit more complience, but i think i now need to change rears from 250lb to around 175lb, its a real shame as i got the car all corner weighted at procomp
bi22le, i have emailed marc, and marc got me to call Kevin @ protech but Kevin needs to know what to valve them to!!
paublo999
posted on 12/7/10 at 05:43 PM Reply With Quote
Yes all four dampers were done. Matt and screw others advised me that the standard dampers don't have enough adjustment for our light weight cars.
Depends on what you are using the car for. I benefitted from dropping the rear spring rates, overall grip went up
The fronts are more down to preference.
Johneturbo
posted on 12/7/10 at 05:58 PM Reply With Quote
Well the rears.. matt set them up on about 4 clicks which was fine for compression but there wasn't any rebound control, i could feel the rear over extend on yumps in the road, so i had to wind them up to 7 clicks to control the rebound but the compression is to high but lighter springs on the rear should cure that.
paul did you have any problems with front lower bones?
paublo999
posted on 12/7/10 at 06:57 PM Reply With Quote
Yes. Locking nuts worked loose and the rod end popped. Not nice.
