Author: Subject: M14 rod end with 16mm hole?
Miks15
posted on 12/7/10 at 07:49 PM Reply With Quote
Anyone know of anywhere i can get and M14 female rod end, but with a 16mm hole?
This is to suit my on going quest to connect my steering up
blakep82
posted on 12/7/10 at 10:08 PM Reply With Quote
think you'll need some extentions on the steering arms too won't you?
in which case, i think you'l find it easier to get custom extentions made up. M14 thead in one end, M16 thread in the other, for a male rod end to screw into?
i think thats how mine are on the truck?
i'll go and measure the rod ends on the uprights
edit
i couldn't measure properly without taking it all apart, but the rod end in mine looks to be 1/2", the the extention is metric one end, and imperial in the other.
if i remember your photo right, you'll need extentions anyway
[Edited on 12/7/10 by blakep82]
________________________
Miks15
posted on 12/7/10 at 10:34 PM Reply With Quote
yep i do needc extensions, but i already have some standard extensions. so hoping i can use these still
flak monkey
posted on 13/7/10 at 06:04 PM Reply With Quote
M14 to M16 extensions would be the cheapest and easiest option.
Sera
http://www.motosera.com
