Author: Subject: bleeding rear breaks problem
spiderman01980
posted on 16/7/10 at 07:12 PM Reply With Quote
I`ve got a set of rear vented calipers from a ford scorpio cosworth and have had a big problem trying to bleed them, my neighbour(a mechanic) even came round with one of those bleeders that work of a compressor and suck the fluid out, and still no luck, i`ve got the bleed nipple on the bottom and my neighbour thinks that might be the problem, does the bleed nipple need to be at the top?
[Edited on 16-7-10 by spiderman01980]
alexg1965
posted on 16/7/10 at 07:23 PM Reply With Quote
Yes, that's the problem. Take the caliper off, position it with the bleed nipple uppermost and it should bleed properly.
flak monkey
In answer to your question.....yes it does.
Take the caliper off and invert it on the flexi when bleeding.
Sera
http://www.motosera.com
Dingz
posted on 16/7/10 at 07:24 PM Reply With Quote
Yes!
Either swap them over. ie r/side l/side or you take them off to bleed, turning them up the right way with a block of wood or similar between the pads. Then don't forget to refit.
went on and on.
arrow-engineering
posted on 16/7/10 at 07:33 PM Reply With Quote
brakes
as you are going to bleed them anyway you may as well swap them left to right now. its only undoing the flexis and then 4 bolts.
spiderman01980
posted on 16/7/10 at 07:40 PM Reply With Quote
the only reson i fitted them that way round was for an easier fitment of the handbrake cable!
RazMan
posted on 16/7/10 at 11:17 PM Reply With Quote
Many people fit them upside down for the same reason - I did the same with my old Sierra calipers.
As already mentioned, simply whip them off and get the nipples on top and bleed them again.
Raz
Paul TigerB6
posted on 17/7/10 at 10:47 AM Reply With Quote
LOL - some mechanic if he didnt laugh at you and tell you with 100% certainty that it was the problem!! Must be one of these new fangled technician that need a diagnostics code......
spiderman01980
posted on 18/7/10 at 02:22 PM Reply With Quote
thank you guys i have now bled the brakes and its all good!!
