Major Stare
posted on 16/7/10 at 10:23 PM |
2pot or 4pot.... that is the question
Currently have standard M16 2pot calipers.
Would lightweight 4pots make a difference/improve braking?
Jon "FISH"
austin man
| posted on 16/7/10 at 10:48 PM |
4 pots should improve it as would green stuff pads or grooved discs
cliftyhanger
| posted on 17/7/10 at 06:10 AM |
Mintex 1144 pads......that will improve things no end. Not a fan of greenstuff, no improvement over cheapo pads when I tried them. Now, the really
old asbestos pads (sadly not sold for many years, but do turn up as old stock sometimes) are ACE but usual caveat.
On a light car the brakes are not really stressed. So yeas, a change will improve things, but unless you are experiencing problems, I wouldn't
bother. Spend the money elsewhere where you will get a better return.
Dusty
| posted on 17/7/10 at 07:01 AM |
Another vote for keep the calipers, fit mintex 1144, avoid greenstuff on a seven like the plague.
I have just changed from greenstuff to mintex and it has transformed the braking on mine.
[Edited on 17/7/10 by Dusty]
Surrey Dave
| posted on 17/7/10 at 02:36 PM |
Mintex
Another vote for Mintex 1144 , they give a massive improvement with standard m16 calipers.
| posted on 19/7/10 at 06:47 AM |
As above also make 100% sure the caliper pistons are moving freely and the pads can slide freely in the caliper.
If you want the brake pedal to be more responsive fit a smaller bore master cylinder --- from a non-servo Mk1 Fiesta or non-servo Mk1 Polo/Golf
or the Fiat12/Lada master cylinder.
[Edited on 19/7/10 by britishtrident]
bimbleuk
| posted on 19/7/10 at 08:59 AM |
I went from Sierra brakes to Wilwood and only after fitting some Mintex pads did the braking actually noticeably inmprove. The lighter calipers, hub
and uprights I fitted benefitted the handling more.
