lsdweb
posted on 18/7/10 at 11:21 AM |
2005 R1 Engine (5VY) for sale
Hi All
In order to concentrate on my Lotus Elan rebuild and get some cash, I’m selling my low mileage R1 engine. I bought this from PaulTigerB6 on here and
ran it in my single seater for half a season - two sprints and one and a bit (in the trees after 20 seconds!)hillclimbs.
The specification is as follows:
Really low mileage 5VY ( Paul has confirmed 5805 miles when he bought it - he never ran it and i've put about 200 miles on it only! ) engine
complete with:
Throttle bodies (and tb loom)
Carbon fibre airbox and K&N filter (mid engine setup)
Starter
Thermostat.
Regulator / rectifier.
The modifications are as follows:
Sump baffle (Nitram)
Blanked off AIS (carbon fibre blanks) – I will include the AIS
VDO Oil temperature sensor in sump
VDO Oil pressure sensor on end of braided flexi hose - photo
36/1 crank trigger wheel so that you can use an aftermarket ECU such as Emerald, Megasquirt etc. I’ll include the original as well. I may also include
the Emerald maps that cost me a fortune on the rolling road!
Sump and oil filter are wirelocked in place.
The engine doesn’t come with the ECU and loom as I ran it on an Emerald. I’ll throw in any other bits I may have like spare coils, oil etc..
I’m open to sensible offers via U2U.
I’m in South Wales but travel a fair bit and if you’re really keen, I’m driving to Sunderland on Tuesday – home Wednesday so could meet up!
Regards
Wyn
[Edited on 18/7/10 by lsdweb]
hobbsy
posted on 18/7/10 at 12:51 PM |
Sorry for the hijack but is there any benefit (other than weight) in blanking off the AIS? I guess if you ran the bike clocks you'd see an
error code?
lsdweb
posted on 18/7/10 at 01:36 PM |
Mileage confirmed at 6000 (thanks Paul).
Blanking off the AIS probably makes it easier to map as well as simplifying the installation and saving a tiny bit of weight!
Wyn
brookie
posted on 18/7/10 at 02:34 PM |
what power does thers run then
lsdweb
posted on 18/7/10 at 02:51 PM |
On the rolling road it was calculated at 182 bhp at the 'flywheel' .
nitram38
posted on 18/7/10 at 04:19 PM |
If working correctly, the AIS closes once the engine is hot, so should not affect mapping.
I've left mine on my car and no detrimental effects.
adithorp
posted on 18/7/10 at 06:45 PM |
As Nitram says, once hot it should close. I left mine on at first but found it was affecting the exhaust gas even when hot as it still leaks some gas
(it shouldn't but did) giving a false, higher, O2 reading. It's only there to improve the emmisions when cold. I removed it and then
modded the housing as part of the improvement to the crank breather. Disconecting the valve doesn't give a fault code.
adrian
http://jpsc.org.uk/forum/
lsdweb
posted on 18/7/10 at 08:03 PM |
Thanks adithorp. It's just one more variable (to remove) when considering mapping.
hobbsy
posted on 18/7/10 at 09:56 PM |
Hmm I might remove the AIS off my 5PW then.
Good luck with the sale BTW!
peteday_uk@btinternet.com
posted on 19/7/10 at 07:53 AM |
U2U me what sort of money you want for this as I may be interested.
Pete.
lsdweb
posted on 20/7/10 at 09:22 PM |
Now on eBay!
lsdweb
posted on 24/7/10 at 07:58 AM |
Sold
