Author: Subject: twin plate clutch
beaver34
posted on 18/7/10 at 09:35 PM Reply With Quote
twin plate clutch
what advantage do these have over a single plate setup?
thanks
phelpsa
posted on 18/7/10 at 09:47 PM Reply With Quote
thanks
Transfer twice as much torque for the same pressure.
Usually used where a small diameter clutch is required, e.g. on race cars where the crank is as close to the floor as possible to lower the centre of gravity
beaver34
posted on 18/7/10 at 09:52 PM Reply With Quote
thanks
thank you,
what the bad points to them? are they noisy? suppose i wont really hear it anyway though
v8kid
posted on 18/7/10 at 10:08 PM Reply With Quote
usually they are sintered metal rather than friction material and some say they are a bit sharp on the uptake. I find them OK though
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
phelpsa
posted on 18/7/10 at 10:09 PM Reply With Quote
You'll lose 'feel', you'll get twice as much friction from the same travel. So it'll be more like a switch.
This is all in theory (studied them last semester at uni), someone who's had experience of using them should be able to advise better.
speedyxjs
posted on 19/7/10 at 09:53 AM Reply With Quote
The idea is that you can get the same friction area from a smaller clutch or a much bigger surface area from the same size clutch. Not really very useful in road cars due to lack of travel imho.
