Author: Subject: how to assemble braided hoses?
andrew-theasby
posted on 30/5/04 at 03:48 PM Reply With Quote
Hi, im a bit suprised i have to ask this as i thought it would be simple but nothing ever is I had a look through the forum and decided to get my hoses unions etc from rally design like most of you seem to. I cant see how the brass ring nips on the tube as i can run the nut down all the way and it only just seems to touch on the taper. Also do i need to strip the braiding off where it crimps on to the plastic or does this go over the tapered brass bit?? which would explain why the nut runs all the way down at the mo. Hope someone can understand this as its puzzling me at the mo. Thanks.
OX
posted on 30/5/04 at 05:11 PM Reply With Quote
if your not sure dude let some one else do it for you,its not worth the risk
Ben_Copeland
posted on 30/5/04 at 05:45 PM Reply With Quote
I was wondering this too... Think i got it right, but not sure... Got all my bits from Darren @ GTS.
Couldn't get the bring ring over the braided bit. Pushes on the plastic tube ok tho... seems to grip fine when all done up
Ben
Locost Map on Google Maps
Enter Your Details Here
andrew-theasby
posted on 30/5/04 at 05:53 PM Reply With Quote
Yep, guess i just needed a break ive sussed it out now with a fresh look at it- braided bit goes over the brass. Thanks any way.
andylancaster3000
posted on 30/5/04 at 10:56 PM Reply With Quote
If anyone doesn't mind parting a few quid on the Classic Ford magazine, this month has a step by step quide to building and fitting braided hoses.
andy.
Ben_Copeland
posted on 30/5/04 at 11:05 PM Reply With Quote
or someone who already has it could scan and paste the pages here
Ben
Viper
posted on 31/5/04 at 05:26 AM Reply With Quote
there is a thread in the sva section about braided hoses, if you are planning to make your own it might be worth you having a look.
Tim
Ben_Copeland
posted on 31/5/04 at 08:03 AM Reply With Quote
"Compression joints in hydraulic pipes should be swaged,and not formed using separate ferules"
You mean that bit ???
Worth reading this thread Link
Mine are exactly same as ones shown by Mark
Ben
Viper
posted on 31/5/04 at 08:16 AM Reply With Quote
No, i have been told that braided hoses that are not TUV approved will soon be illegal for road use.
Tim
NS Dev
posted on 31/5/04 at 08:17 AM Reply With Quote
In my "draft" manual (March 2004) it says (quoted exactly)
"Compression joints of the type using separate ferrules are not considered suitable for joints on hydraulic brake lines OTHER THAN IN THE CASE OF A HOSE DESIGNED FOR A HIGH PRESSURE APPLICATION THAT INCORPORATES AN INNER SUPPORT SLEEVE IN THE COMPRESSION FITTING"
I.e. the rally design fittings are fine cos they do!
In any case, as I have said elsewhere, this rule is a bit crazy as these hose assemblies are (generally) made to aerospace specs for aeroplane and helicopter hydraulic systems!
andylancaster3000
posted on 31/5/04 at 09:55 PM Reply With Quote
since you asked so nicely here are is the guide to building hoses... (in photo archive)
not sure mr. classic ford magazine would appreciate it though
Ben_Copeland
posted on 31/5/04 at 10:04 PM Reply With Quote
Excellent, well done mate... Just the way i did it too... well sorta lol
Ben
