Author: Subject: not using a donor steering column
interestedparty
posted on 24/7/10 at 11:51 AM Reply With Quote
I like the idea of making my own column using a splined shaft running in roller bearings, and with a direction indicator switch mounted on the dashboard. I know some Westfields are like this.
I don't like the look of Sierra columns, and I think it would look neater, and make the wiring easier, to have all the switches on the dasboard (I won't be having a windscreen).
Things is, where can I get a shaft that will run in generic bearings and yet will have the right kind of splines for mounting the steering wheel? I would be using a collapsible boss BTW. I did think of using a removable wheel because they come with a bit you can weld onto a 3/4 inch shaft, but apparently that's a doubtful for the IVA.
MakeEverything
posted on 24/7/10 at 12:59 PM Reply With Quote
But after a period of time, the roller bearings will wear, and replacing them will be problematic??
Originally posted by interestedparty and with a direction indicator switch mounted on the dashboard. I know some Westfields are like this.
Dont use the wiring, just use the column?
Originally posted by interestedpartyThings is, where can I get a shaft that will run in generic bearings
Get bearings to fit the shaft, not the other way around. Bearings come in all shapes and sizes. I get mine from Brammer.
Originally posted by interestedpartyand yet will have the right kind of splines for mounting the steering wheel?
Arent they generic? My column is off of a sierra and i mounted a removeably wheel boss directly onto it.
Originally posted by interestedpartyI would be using a collapsible boss BTW.
Collapsible boss?????
Originally posted by interestedpartyI did think of using a removable wheel because they come with a bit you can weld onto a 3/4 inch shaft, but apparently that's a doubtful for the IVA.
As said, you can buy them splined to fit onto the shaft without welding.
Kindest Regards,
Richard.
interestedparty
posted on 24/7/10 at 01:17 PM Reply With Quote
I was thinking of bearing like this, I assume they have rollers insided but maybe they are ball bearings, buut that probably doesn't matter anyway
http://simplybearings.co.uk/shop/Housings+&+Inserts-Housings/c16_17/p22933/SBPP204-12+Pressed+Steel+Pillow+Block+Housing+with+3/4+inch+Insert/prod uct_info.html
Most steering wheels come with a collapsible boss these days, I know the Mountney ones do, it means you don't have to have a collapsble section in the column itself, as long as the whole steering system is 'protective'
What can you buy splined onto the shaft without welding? Do you mean the bit that takes the removable wheel, cos I don't want a removable wheel, I want the shaft with splines on.
wicket
posted on 24/7/10 at 02:17 PM Reply With Quote
I have a Mountney steering wheel and boss and the boss is not collapsible, it's solid al.al. The splines are not generic, they vary according to column being used.
I think you will have a problem come IVA time with a tailor made steering column, it says in the manual that it must be of an approved standard (marked or documentary evidence
Here's section 14 note 3 from the manual:-
The steering control and column assembly must provide adequate protection to the driver by absorbing energy from a driver-steering wheel impact. This is the case if the steering control has an approval (evidence may be markings or documents), or is similar to an approved steering control. The vehicle should be assessed using the material in Annex 1.
daniel mason
posted on 24/7/10 at 07:01 PM Reply With Quote
can you reach your dashboard (to turn indicators on) with your harness on?
interestedparty
posted on 24/7/10 at 07:20 PM Reply With Quote
I can reach the dashboard, I'll make sure of it, and won't even need a long stalk switch because I'll set it all up so the wheel doesnt come out too far from the dashboard to far. I've got a lot of choice over where the scuttle goes etc, and if I find it's a problem I will have an extending back area o n the dashboard to contain the direction and other needed switches like horn, lights etc
Anyway, Ive kept searching and found the answer, it should have been obvious to me, but there you go, exactly what I want, including a lock and keys for £115
http://www.westfield-sportscars.co.uk/shop/product.asp?numPageStartPosition=6&strPageHistory=cat&strKeywords=&strSearchCriteria=&PT_ID =72&P_ID=160
and the matching wheel with collapsible boss is only another £80 (I've seen them and they look really smart) so looks like that is what I will be doing.
Don't know why the link wont work, I copied it from the Westfield site, anyway it's in the steering section
[Edited on 24/7/10 by interestedparty]
wicket
posted on 24/7/10 at 09:09 PM Reply With Quote
Won't you also need the lower steering column section for another £72?
907
posted on 25/7/10 at 04:57 AM Reply With Quote
I too never liked the looks of the sierra shaft.
Vauxhall stuff looks a lot neater.
My mate has a Honda engined Dax that needed an extra u/j to get round the exhaust. He did that with mostly Vauxhall bits,
though he did have to cut one shaft to length and have the end splined.
I followed Uncle Ron's advice for alternatives in "the book" and used the Nova column.
The end is female, so just needs a male shaft with two flats on it, so nice and easy to make. (or get made)
Paul G
