Author: Subject: Wheel bearing life
Snuggs
posted on 29/7/10 at 10:12 AM Reply With Quote
Wheel bearing life
How many miles should rear wheel bearings last ?
I had an MOT on the Viento yesterday and there was play in the OSR bearing.
They were new when the car was built and have done less than 10000 mls.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
interestedparty
posted on 29/7/10 at 10:14 AM Reply With Quote
are they sure it was the bearing itself, any possibilty of the bearing housing bolts being a bit loose?
big-vee-twin
posted on 29/7/10 at 10:25 AM Reply With Quote
If the bearings aren't Torqued up correclty, they wear prematurley.
http://www.triangleltd.com
mark chandler
posted on 29/7/10 at 02:30 PM Reply With Quote
correctly set up on a heavy car, 100k miles, on a light car ~200k miles.
If its worn out then incorrect adjustment or forgot to lubricate with clean grease
Snuggs
posted on 30/7/10 at 08:42 PM Reply With Quote
Yep it was loose bolts, I will check the other side tomorrow
Be warned gents, CHECK YOUR NUTS
