-matt
| posted on 7/8/10 at 09:36 AM |
removing front hub nuts?
im trying to remove the hub nuts of my sierra hub/uprights.
am i correct that the drivers side (yellow nut) is is right hand thread, and the passenger side (blue nut) is left hand thread?
as i have been trying both but cannot get them to budge, the hub is just spinning in the vice.
so any ideas?
cheers
snapper
| posted on 7/8/10 at 09:43 AM |
Put a bar through the studs to wedge it
Put nuts on the studs to stop damage to the threads
I eat to survive
I drink to forget
bigrich
| posted on 7/8/10 at 09:47 AM |
open the vice wide and drop the studs in, you wont damage them and the hub cant spin then. then use a big bar or ratchet with a tube to undo.
Cant remeber if one is LHT but would guess it is as they use the same method on the rear.
-matt
| posted on 7/8/10 at 10:22 AM |
thanks
i have done it.
after realising that the hub wasn't going around anymore, i was doing i the wrong way.
the drivers side is left hand thread. and the passenger side is right hand, which is the opposite to the rears.
