Bumble
posted on 22/8/10 at 04:00 PM |
Help.......F*!*&*g Crank Pulley!!!!!
Help please....been struggling for the past 2 hours trying to loosen the crank pulley bolt (Silvertop Zetec). I have the engine on a stand (minus
sump). I tried screwing in 2 of the flywheel bolts and bracing against them whilst trying to "shock" the pulley bolt into submission but
the bloody thing won't budge. It's not reverse thread is it??
Worried I'm going to round the bolt off if I keep hitting it. What else can I try??
Thanks,
Matt
SPYDER
posted on 22/8/10 at 04:07 PM |
An impact gun will get it off in a jiffy (if you have one, of course)
Maybe someone on here more local to you than I am will nip round with theirs.
And, no, it won't be a reverse thread.
Geoff.
RazMan
First of all, do NOT hit the crank bolt - you stand a serious risk of damaging the crank bearings.
A good fitting socket and breaker bar is the only way I'm afraid. If that doesn't work, I think Ford does a special tool but you
wouldn't want to buy one.
Can you jam the starter ring and lock up the crank that way?
[Edited on 22-8-10 by RazMan]
Raz
big_wasa
posted on 22/8/10 at 04:27 PM |
I think the pulley has two holes in it so you can put two bolts through a bar to hold the pulley or drill two holes in a bar and bolt it to the crank,
fly end.
Is this your 2L ?
Make sure you use an 18mm 6 point socket.
[Edited on 22/8/10 by big_wasa]
WestfieldSEI
posted on 22/8/10 at 04:46 PM |
I DON'T reccommend this but it worked for me after I struggled for several hours trying to get the crankshaft pulley nut off a FIAT Panda. I
read about this technique on another forum somewhere....
Get a decent ring spanner (obviously one that is the right size), put it on the nut, then engage the starter VERY briefly (make sure you have removed
the spark plugs or leads as well, you don't want it to start!). The theory is the spanner will spin round, make contact with something hard (the
floor hopefully) and shock the nut loose.
As I say it only took two attempts on the Panda after I had spent several hours with ever increasingly large levers trying to undo it.
Of course if you have access to an impact gun try that first!
[Edited on 22/8/10 by WestfieldSEI]
Bumble
posted on 22/8/10 at 04:58 PM |
Hi Wasa,
Yep its the 2L. All ancillaries stripped off, engine degreased, block painted, sump off......just can't get the f'ing crank pulley bolt
loose in order to change water pump and fit new cam belt. Seriously miffed.
Matt
fly end.
Is this your 2L ?
snapper
posted on 22/8/10 at 06:23 PM |
Is it on an engine stand or on the floor?
If it's on a stand then wedge the flywheel and use a big bar on the crank nut, it will give.
To help it you could apply some heat, let it cool, soak it in WD40, then the next day heat it again and use the big bar
[Edited on 22/8/10 by snapper]
I eat to survive
I drink to forget
speedyxjs
posted on 22/8/10 at 06:31 PM |
that is exactly how i did mine. Works very well.
T66
posted on 22/8/10 at 06:35 PM |
Can be harder if on an engine stand, so lie it down if you can.
Softwood wedges on the crank to jam it...
No hammering, get someone to put their weight on the engine for you, with it lying down.
Strong bar and socket, and if you have it a piece of scaffold pipe to extend your lever may help. A hex socket will be more secure than the other type
I cannot recall the name of.
Easiest way is a windy gun/nut gun but Im guessing you havent got one.
