omega 24 v6
| posted on 28/8/10 at 09:14 PM |
Recommend me a master cyl
as the title I need more "feel to the brake pedal and so am on the hunt for a replacement.
On here the search throws up a few but here's the rub
I need one with a 19mm bore. Preferably a remote reservoir ( new one from raldes?) and it needs 10x1mm threads. I have a sierra m/cyl at the moment
with a mk4 escort pressure valve in the rear line and would like to keep this balance.
robocog
| posted on 28/8/10 at 10:23 PM |
I went Sierra master cyl to a Fiat item
Only had to make up one new line (only because I ditched the Fiat bias doo dah on the bulkhead as I got sick of replacing them on an anuual basis due
tio them going leaky and failing the MOT)
Unions are the same thread
M/C was cheap as chips on eBay and is for a remote res- which I nicked form a Daihatsu Hi Jet
Only non straight forward bit was turning the take offs for the M/C to remote res and finding suitable tube to connect the two
Transformed the braking feel for the better and the balance is just fine
Will try and find my original posting as I think I gave part numbers etc
Regards
Rob
robocog
| posted on 28/8/10 at 10:29 PM |
Found it ...
Linky
19.05 which is pretty close :-)
Regards
Rob
RazMan
| posted on 28/8/10 at 10:30 PM |
You say that you want more 'feel' but you specify a 19mm bore. Is that larger or smaller than your current one?
I would go for a Girling 0.75" but that seems rather large for brakes - what size are your slave cylinders?
*edit* Just re-read your post and you are using it for both front & rear circuits - doh!
[Edited on 28-8-10 by RazMan]
Raz
gregs
| posted on 29/8/10 at 03:32 AM |
I went from a sierra cylinder to a golf mk1 item - haven't driven it on the road again yet but all signs are good!
adithorp
| posted on 29/8/10 at 07:10 AM |
Isn't 19mm biggger than you have now? That will give less feel/harder pedal.
For more feel the common change is from a Sierra master cyl' to an early non-servo Fiesta one.
adrian
http://jpsc.org.uk/forum/
omega 24 v6
| posted on 29/8/10 at 08:32 AM |
I thought sierra master cyl was 22mm dia??
So 19 is what I'd decided to go for.
Are the fiat ones 10 x1mm threads for the brake lines??
[Edited on 29/8/10 by omega 24 v6]
Davegtst
| posted on 29/8/10 at 09:13 AM |
If you mean the fiat 124 M/C then no the threads aren't M10 x 1.00. Pretty sure they are M10 x 1.25, i've got one on mine but obviously
havent used it yet.
adithorp
| posted on 29/8/10 at 09:25 AM |
Could be, never measured one. Just assumed it was smaller (you know what they say about assumption).
[Edited on 29/8/10 by adithorp]
