PuppiesBalls
| posted on 2/9/10 at 12:33 PM |
Which front brakes should i go for?
Hi gents, Ive gone for the RD ally uprights which are suited to the Wilwood Powerlite 4-Pot's
I now just need to decide which type & size brakes im going to run on the front,
I will be using the car on the track so the'll be worked quite hard, The car will weigh around 700kgs.
Would I need vented discs or could I get away with solid discs which would keep the weight down.
Im thinking about going for the Powerlite - 265mm Solid Kit from Rally Design which is just over £300 pound,
Do you think the'll be man enough?
Im running the 250mm sierra non-vented discs on the back
Johneturbo
| posted on 2/9/10 at 01:25 PM |
I've got the powerlite setup with solid discs/groves
i'd also reccomend the mintex pads rather than the smart pads, as they have much better initial bite.
madteg
| posted on 2/9/10 at 04:32 PM |
As above i have the same set up works great.
RazMan
| posted on 2/9/10 at 05:05 PM |
I've got the same setup but with vented discs - they never get warm enough and would swap for solid discs given half a chance.
Whatever you do DON'T get the Smart pads as they will scare the crap out of you - Mintex all the way
Raz
ashg
| posted on 2/9/10 at 05:28 PM |
i had smart pads but they may aswell have been blocks of wood.
mintex 1144's are good but have a tendency to squeal. well they did on my car
now using yellow stuff, no squeal and initial bite not quite so good but much better on the edge.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
