Author: Subject: 2.0 Zetec Map Anyone??
Bumble
posted on 6/9/10 at 08:27 PM Reply With Quote
I have a 2.0 Zetec on R6 TB's running MS1. Got the engine up n running but it's very rich so was after some maps of similar setups to compare against.
Thanks,
Matt
fatbaldbloke
posted on 7/9/10 at 08:55 AM Reply With Quote
First thing: Did you use the inbuilt ReqFuel calculator? For some reason this gives values around 12-13, which are more-or-less double what you want.
Bumble
posted on 7/9/10 at 01:30 PM Reply With Quote
Yes I did...it gave me a value of 14.6 but having already read several posts on here I've ended up with 7.5 as required fuel rate. Injector staging is set to simultaneous.
