Author: Subject: MX5 outer CV joint
liam.mccaffrey
posted on 7/9/10 at 11:04 PM Reply With Quote
MX5 outer CV joint
Is it pressed on? Anyone taken one off before?
Build Blog
Build Photo Album
indykid
posted on 7/9/10 at 11:14 PM Reply With Quote
hub flange onto the the CV?
they're a tight clearance fit but they do tend to corrode on pretty heavily on early cars. i've heard of people changing uprights because the hub flange was stuck so solid, though that doesn't necessarily mean they persevered at all
tom
liam.mccaffrey
posted on 7/9/10 at 11:54 PM Reply With Quote
I managed to remove the drive shafts from the uprights, you're right they are bloody tight!!!!!
What I want to do is remove the outer CV joint from the actual drive shaft
Build Blog
Build Photo Album
