Author: Subject: extending steering uj
tofferson4
posted on 8/9/10 at 09:29 PM Reply With Quote
hy i have a sierra column and escort rack whats the best way of extending the bit between them, are there rules and regs to follow or can i cut and weld.
its a bit comfusing as some people say to sleeve and others say that will make it fail sva/iva
[Edited on 8/9/10 by tofferson4]
adithorp
posted on 9/9/10 at 06:50 AM Reply With Quote
Mine is just cut and sleeved. I think thats how most are done. I've never heard of a car failing test for it.
adrian
http://jpsc.org.uk/forum/
mistergrumpy
posted on 9/9/10 at 03:09 PM Reply With Quote
I've cut and sleeved mine too and as an addition I pinned it as well.
MikeR
posted on 9/9/10 at 03:37 PM Reply With Quote
cut and sleve - although do the cut at an angle to increase the welded section.
Just about to do mine again (long story - need it about an inch longer!)
This time I'm doing it with about a 30 degree angle on the outer extension steel which is about 2.5mm thick. Making sure the two cut sections stick inside the extended section by about 4 or 5 inches, I'll then drill two holes in the extension about an inch from the end of the inside section and puddle weld that as well.
On the previous joint i actually made it so the shafts inside touched and i put a slot in each with a lump of 3mm steel between them. The idea being that if the outside section ever gave way - this would give me some steering whilst i got to the side of the road. Very belt and braces. Not doing it this time due to a) no one else seeming to bother and b) the real reason - i haven't got enough steel between the two sections.
tofferson4
posted on 9/9/10 at 09:28 PM Reply With Quote
ok cut and sleeve it is ill do some holes and puddle weld also for added strenth thanks for all the help
