Author: Subject: pedal box help
needforspeed
posted on 19/9/10 at 03:55 PM Reply With Quote
pedal box help
hi, this is going to be a very simple question for mose! ive just fitted a pedal box and have been supplied 2x .7 and a .625 master cylinder im just wandering which way they go round on the pedal box does the .625 for the front brakes go next to the clutch or away from it? im using a dash mounted adjuster so will matter thanks in advance
RazMan
posted on 19/9/10 at 04:12 PM Reply With Quote
I doesn't really make any difference which side the front & rear m/c go - as long as you know which way you mounted them
Your dash mounted adjuster will probably dictate which way they go anyway, as they need a smooth cable route with no sharp bends.
Raz
posted on 19/9/10 at 04:39 PM Reply With Quote
Just be aware that a dash mounted adjuster may fail an IVA test if the car is for road use
needforspeed
posted on 19/9/10 at 06:50 PM Reply With Quote
thats great thanks for your help, cars already on the road so no probs there
