iceman26
| posted on 5/10/10 at 09:04 PM |
prop length
this my be strange question but is there a min prop length
mark chandler
| posted on 5/10/10 at 09:52 PM |
No, not really.
If you go short enough maybe something like a rotoflex coupling may be more appropriate.
speedyxjs
| posted on 6/10/10 at 07:36 AM |
No there is not. I have even seen drag racers with no prop. The gearbox output is directly connected to the diff with a UJ!
Bluemoon
| posted on 6/10/10 at 12:25 PM |
There probably is for a live axle..
matt_claydon
| posted on 6/10/10 at 12:58 PM |
Length isn't relevan't, but there is a maximum angle for UJs, so you need to make sure that the prop is long enough to keep the UJs within
their working limits for all possible engine/suspension movement.
Using only a single UJ between gearbox and diff would require near perfect alignment, otherwise you would get cyclical speed variation which is
normally cancelled out by having two opposing UJs.
meany
| posted on 6/10/10 at 07:36 PM |
interesting read below.
http://www.iedls.com/asp/admin/getFile.asp?RID=10&TID=28&FN=PDF
from here.
http://www.iedls.com/Education-Zone.asp
