Author: Subject: If you can not find Zetec engine number check with camera!
AdrianH
posted on 5/10/10 at 09:10 PM Reply With Quote
Just a hint, may be worth trying for all those missing engine numbers.
picked up a 16V Zetec 1.8 tonight told it was a certain type could not find any engine number. Cleaned off the area where it should be and to my eyes no stamp.
Cleaned further with emery paper and there could possibly be some markings!
Got the digital camera shot from slight angle and zoomed in to the result. There is a engine number stamped there but not how I would expect it, as dots!
	Zetec engine no
Zetec engine no
SO RDA and TG give type and age.
Thought it may help some others.
Adrian
[Edited on 6-10-10 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
posted on 5/10/10 at 09:17 PM Reply With Quote
I cleaned mine up and rubbed some boot polish on it them cleaned that off. Brought the number up as well.
RAYLEE29
posted on 6/10/10 at 07:16 AM Reply With Quote
TG Thatll be april 96 then.
Ray
ashg
posted on 6/10/10 at 07:33 AM Reply With Quote
winter upgrade Adrian
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
doddy
posted on 6/10/10 at 03:46 PM Reply With Quote
will give that a try
i should have looked before i put it in the car
posted on 6/10/10 at 06:04 PM Reply With Quote
Might cover up a few numbers. It would be a shame for someone with some number punches to clone your engine!!!
AdrianH
posted on 6/10/10 at 06:06 PM Reply With Quote
Hi ash,
No not a winter upgrade thinking of next car.
Have accumulated a few engines gearbox, diff and axles etc, initially as spares but could be doing second build next year!
Adrian
Have changed the picture from Ben's comment although a 2006 engine is not going to get pre CAT, you never know what people want.
Ian D
posted on 6/10/10 at 06:45 PM Reply With Quote
Look on the head by the water pump the engine number is stamped there as well. It may help you sort the missing numbers / letters. assumes you have a matching head and block
Ian
vindi93
posted on 20/5/17 at 11:19 PM Reply With Quote
The number by the water pump is that the engine number or the engine code?
