Matthew_1
posted on 11/6/04 at 10:15 AM |
Sierra tie rod dimensions
Does anyone know the length of a sierra tie rod, and the size of the tread as well? Ideally I need a rod 250mm long with an M14 thread.
Steve Hnz
posted on 11/6/04 at 11:29 AM |
Matthew, The Sidem PDF catalogue lists the Sierra tie rod at 270mm. BTW thats a nice looking inboard front suspension set up in your archive, it looks
close to what I`d like to be heading toward. ( see the Inboard front suspension thread down the page a bit). Cheers, Steve.
posted on 11/6/04 at 12:56 PM |
Sierra M14x2
bigger Volvo also M14x2
Volvo 340 M14x1.5
VW group, Peugeot group , most Fiats & Renaults M14x1.5
Fiat/Seat Panda M14x1
[Edited on 11/6/04 by britishtrident]
Northy
posted on 11/6/04 at 07:40 PM |
Is that 270mm from end to end?
Whats the lenght of the tie rods on a MkII Escort rack?
Anyone know if they'll fit a MkII Escort rack?
G
Graham
posted on 11/6/04 at 09:51 PM |
Escort and Sierra racks are completely different.
Northy
posted on 11/6/04 at 10:21 PM |
BritishTrident,
Not being funny, but do you know that for a fact? Will Sierra Tie rods not fit an Escort rack deffo?
Graham
jolson
posted on 11/6/04 at 10:39 PM |
I had an escort rack and a sierra rack here at the same time. The ends are definitely different and cannot be swapped. The Escort rack end has a
male thread on it and forms part of the joint. The sierra has a female thread, and the joint is part of the track rod. In the end, I gave away my
escort rack because I couldn't see an easy way of shortening it without lots of machining. The sierra rack was as easy as chopping the end off
and drilling and tapping a new hole.
John
Northy
posted on 11/6/04 at 10:45 PM |
Cheers.
Ok then, I need a good idea how to extend my MkII Escort rack. At the mo I can only get about 10mm of the tread into the ball joint
Which won't fill me full of confidence when I'm flogging it!
Graham
