Author: Subject: Whats this bush ?
splitrivet
posted on 11/6/04 at 02:17 PM Reply With Quote
Whats this bush ?
Hey up chasps,on the cortina axle just above of and either side of the diff is a largeish metalastic bush,whats this for then ?
Cheers ,
Bob
stephen_gusterson
posted on 11/6/04 at 02:20 PM Reply With Quote
what a dissapointing thread.... Alanb's gonna feel let down too.....
atb
steve
splitrivet
posted on 11/6/04 at 02:27 PM Reply With Quote
Notice how you were the first to view it tho Steve
Alan B
posted on 11/6/04 at 02:34 PM Reply With Quote
But I'm not far behind......
Actually I can answer this one....
The bush is where the short (angled) trialing arms would fit in the original application......not needed now of course...
posted on 11/6/04 at 02:36 PM Reply With Quote
The void bush it was part of the standard 4 link axle location -- not exactly precise.
I change zillions of those back in the days of the Mk3+ Cortina --- standard Mot failure every year.
splitrivet
posted on 11/6/04 at 02:44 PM Reply With Quote
Cheers fellas
zilspeed
posted on 11/6/04 at 02:46 PM Reply With Quote
Ye olde void bush.
Following a cortina was scarey because of these. The axle could move about three feet sideways over a lollipop stick left on the road
posted on 11/6/04 at 03:27 PM Reply With Quote
Easiest way to get them out was to burn the buggers with the welding tackle.
jollygreengiant
posted on 11/6/04 at 04:22 PM Reply With Quote
Nah, bush puller and air gun. 20 seconds tops.
Themmz warz the dayz.
Jon Ison
posted on 11/6/04 at 05:06 PM Reply With Quote
But on a locost cut the whole lot off, lose about a kilo in weight at same time...
Mark Allanson
posted on 11/6/04 at 06:22 PM Reply With Quote
Sorry, Jon, they have to stay, they paid my mortgage btween 1978 and 1985. A testamony to Ford consumerism
Dale
posted on 11/6/04 at 07:01 PM Reply With Quote
If they are like the fourlink bush holders on my tbird axle they work just fine as a place to attach the cherry picker to for moving them about
Dale
posted on 11/6/04 at 09:55 PM Reply With Quote
Very easy to knock out with cold chisel -- burning synthetic rubber bushes produces very nasty acid by products --- heating them enough to de-bond is ok burning very dangerous.
Mark Allanson
posted on 11/6/04 at 10:02 PM Reply With Quote
Agree with BT, the most stubborn ones would get the rubber drilled, and a junior hacksaw through the outer sleeve, then a good belt with a sharp punch.
majority would draw out with the ford puller
