Author: Subject: help needed, propshaft come off
markie t
posted on 10/10/10 at 09:36 PM Reply With Quote
was out tonight and on the way home my propshaft decided to detatch itself from the gearbox (99 r1) and ended up coming home on a recovery truck. As a result of flailing around it has damaged the threads slightly on the shaft that the adaptor sprocket goes onto, can somebody please let me know if this is a main shaft for the gearbox and would the threads be ok to be tapped and die'd and re bolted back together, thanks, mark.
eznfrank
posted on 10/10/10 at 09:39 PM Reply With Quote
Did you have a prop catcher?? Sounds like you got off VERY lightly if that's all it did!!
markie t
posted on 10/10/10 at 09:48 PM Reply With Quote
yes i think so, there is a large rubber mount that holds the propshaft central just inside the front of the tunnel, it is only front end of the prop that has been spinning/flailing in the engine bay, i sh*t myself when it happened, sounded horrible!!!
snapper
posted on 11/10/10 at 05:20 AM Reply With Quote
When you find a solution and effect a repair, use thread lock on every nut and bolt, also consider wire locking critical componants.
I eat to survive
I drink to forget
mangogrooveworkshop
posted on 11/10/10 at 07:50 AM Reply With Quote
Might help putting your location in to see if theres other builders in your area who could help you out <<<<<<<<<<<< poulton nr blackpool.
A prop catcher may be needed and a very good check of all the components in the drive train.
a person that would help you is AB engineering Andy Bates. he is a specialist in the bec field.
Breaker
posted on 11/10/10 at 09:29 AM Reply With Quote
On many pictures of BEC-chassis I've seen(Including Indy R that I have) the output flange of the gearbox is not parallel to the diff flange. This will cause vibration and stress to the gearbox/diff/flanges.
I will certainly reposition the bike engine in my chassis so it is perfectly in line with the diff.
More reading here :
UJ - linky
boggle
posted on 11/10/10 at 11:29 AM Reply With Quote
i cannot get my blade engine parralell to my diff....it just wont fit
u2u me for details
ReMan
posted on 11/10/10 at 01:04 PM Reply With Quote
More reading here :
UJ - linky
It does not need to be perpectly in line, that's why you have a UJ's
But the faces should be roughly parrallel
ReMan
posted on 11/10/10 at 01:09 PM Reply With Quote
Not tempting fate, but surely a prop catcher is after the event?
Prevention beteer than cure an all that
However I agree that it would be very easy at to build in a load more ribs of box/tube section in the tunnel top and sides, which would easily contain it should the worst happen
Breaker
Indeed, that was what I meant.
Liam
posted on 11/10/10 at 08:13 PM Reply With Quote
You dont have to have the input and output planes parallel to be able to cancel out the non-uniform velocity. You just need two joints with the same angle on them - e.g. in the BEC application have the same angle on the sprocket adaptor joint and the centre joint.
Or just stick a rubber cush drive in there!
Breaker
posted on 12/10/10 at 08:12 AM Reply With Quote
I don't quite understand what you're saying. Can you post a small drawing ?
sickbag
posted on 12/10/10 at 08:20 AM Reply With Quote
Given the short-comings of UJ's would it not be better to have the propshaft made up with CV joints instead? Can they be requested when having one made up?
I only ask as I'll be needing one soon and don't like the idea of a UJ failing.
Finally back on the job!
Liam
posted on 12/10/10 at 12:46 PM Reply With Quote
Eg like this...
First joint cancels the second joint. Same principle as those double joints used in offroading when the propshafts are hanging down for big ground clearance.
