Author: Subject: alloy rear uprights for sierra shafts?
CNHSS1
posted on 14/10/10 at 01:48 PM Reply With Quote
follwing on from recent thread where you knowledgable lot helped out, ive another query for you
its seems most 7types use a largely similar design IRS rear upright, generally to take sierra bearing carriers. Does anyone do a vesrion in alloy?
ive seen the Westfield cast items, but as im going to need to modify them (shock operation and upper pickup point) i think its best if i find a fabricated version ideally.
Any suggestions Chaps?
or the lightest steel version at a push
v8kid
posted on 14/10/10 at 03:27 PM Reply With Quote
You can get alloy bearing carriers from the grassracers but as far as I know all the fabricated uprights are steel.
Not sure if alloy is suitable as a material here as fabricated alloy tends to fatigue - cnc from solid would be OK but cost?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
matt_gsxr
posted on 14/10/10 at 03:59 PM Reply With Quote
http://www.mambamotorsport.co.uk/components/uprights.html
http://quaife.co.uk/catalogue/products/d4q1-01
http://www.westermann-motorsport.com/shop/product_info.php?info=p354_RACE-UPRIGHTS-REAR.html
Loads of options
Just all really expensive!
Matt
CNHSS1
posted on 14/10/10 at 04:05 PM Reply With Quote
thanks for the links but they are all cast or billet, was looking for a fabricated and welded version similar to the locost/haynes designs. Price wise none are cheap either, higher echelons of motorsport rather than my clubbie level im afraid
Take the point re fatigue though, maybe will have to go with steel with the ally carriers.
anyone got a weight for a typical locost style rear upright without cast bearing carrier?
[Edited on 14/10/10 by CNHSS1]
minitici
posted on 14/10/10 at 04:51 PM Reply With Quote
Make some from simple billet as per these Aussie racers.
Their basic design is used on both front and rear.
I'm sure you could adapt the design to Suit Sierra bearings and hubs.
Link to Aussie Site
NS Dev
posted on 15/10/10 at 08:01 AM Reply With Quote
If going fabricated, definitely needs to be steel not ally.
You can fabricate a very light steel carrier.
