Thinking about it
| posted on 25/10/10 at 04:56 PM |
What wheel stud length
What wheel stud length is needed?
Front - Cortina hubs
Rear - Sierra
Wheels - RS style 4 spoke Laser wheels
liam.mccaffrey
| posted on 25/10/10 at 06:35 PM |
Can't help with your specific question but I needed to lengthen my tina studs and swapped them for granada ones. from the scrappy. Cheaper
than buying from rally design etc.
Hope that helps
Build Blog
Build Photo Album
big-vee-twin
| posted on 25/10/10 at 09:10 PM |
I used 50mm ones Cortina Hubs Front Sierra Drive flanges on the rear and Alloy wheels fitted, you can actually measure your alloy wheel thickness and
then add the thickness of Hub/Flange and then the thread depth you require for your nuts
http://www.triangleltd.com
