Author: Subject: sierra drums binding
mazie
posted on 28/10/10 at 07:30 PM Reply With Quote
not your usual binding sya, seized piston or sticking handbrake .
all is ok when the drumm is on without the road wheel, when the road wheel is fitted and u start to tighten the brake drum starts to bind, the tighter the nuts.. u guessed it the worse the binding.
I have just changed the wheel bearing but nothing with the brakes was touched. hub nut torqued up as it should be.
any ideas?
thanks to all.
russ
snapper
posted on 28/10/10 at 08:54 PM Reply With Quote
Could be a ridge on the internal drum face
I eat to survive
I drink to forget
