Author: Subject: 13" wheel and caliper problem even with modded spring
daniel mason
posted on 13/11/10 at 02:03 PM Reply With Quote
i ave trial fitted my rear wheels today and even after fitting the shorter sierra caliper springs,although they clear the inside of the rim (just) they foul the wheel balancing weights! can i re locate these weights anywhere else?
flak monkey
posted on 13/11/10 at 02:24 PM Reply With Quote
Yep, just move them over so they clear.
Sera
http://www.motosera.com
daniel mason
posted on 13/11/10 at 02:27 PM Reply With Quote
towards the inside of the rim? they will need to be moved a fair bit as the handrake cable lever also almost touches the wheel! cheers though
flak monkey
posted on 13/11/10 at 02:31 PM Reply With Quote
Yes, doesnt matter where aross the width of the rim they are fitted.
Sera
lewis
posted on 13/11/10 at 03:03 PM Reply With Quote
Ony the fronts need to be dynamically balanced that's what I was told.
Rallye_Mark
posted on 13/11/10 at 05:29 PM Reply With Quote
Do you have a picture of the shorter spring fitted?
posted on 13/11/10 at 06:52 PM Reply With Quote
Unbalanced rear wheels will cause uneven tyre wear even if you can't feel any wobble or shake.
