Kriss
| posted on 15/11/10 at 08:28 PM |
Best way/tips to git a inner diff CV boot
Have just seen a video using a cone to fit a CV boot. My diff to driveshaft boot has a little split so I want to replace.
Ideally, detach the driveshaft diff ed and fit a new boot.I am very put off by dismatling the driveshafts and lobro/cv joint so would like to avoid if
possible
matt_claydon
| posted on 15/11/10 at 08:39 PM |
If you have lobros it's just one circlip to slide the joint off it's splines. Much easier than the cone method. Tripode joints are a whole
different ball game though!
loggyboy
| posted on 15/11/10 at 08:41 PM |
Bought a cone to do the CV on my Clio the other week, you need a stretchy boot, but it worked ok, my only concern was the seal to the drivehaft itself
was quite loose, but a cable tie soon tightened it up ok.
