Author: Subject: Front Bottom Swivel joints
Trollyjack
posted on 19/11/10 at 06:09 PM Reply With Quote
Hi all
I'm new to all this I have just bought a Locost chassis along with quite a few bits that was started years ago.
This will be my first question of many I think
Being built to book
The bottom Swivel joint at the front I have seen advertized as a Maxi Ball joint
But in the book its down as a Cortina MKIII IV & V with 4 bolt holes
Its come with 1 of these allthough i'm going to fit 2 new one's
Will either fit or what ??
TrollyJack
big_wasa
posted on 19/11/10 at 06:24 PM Reply With Quote
The wishbones will have either two or four holes, if two its maxi and so on
I read it at you allready have the wishbones ?
Its easier to make the wishbones for the maxi joints. As they arnt designed for locost use there are some that are more suited than others.
Best ones to get are the new old stock Qh parts. There has been a few post of cheaper ones failing.
[Edited on 20/11/10 by big_wasa]
Trollyjack
posted on 19/11/10 at 07:03 PM Reply With Quote
Will they both fit the hub
TrollyJack
panichat
posted on 19/11/10 at 07:08 PM Reply With Quote
Should both fit.
If your wishbones are one that use cortina swivels I might have a couple of unused ones in my shed that you could buy for a bargain price if you wished. Let me know if you want me to have a look.
Dave
Trollyjack
posted on 19/11/10 at 07:18 PM Reply With Quote
That would be great
TrollyJack
marcjagman
posted on 19/11/10 at 07:26 PM Reply With Quote
If you need any help drop me a line, not too far away in Pontefract.
Trollyjack
posted on 19/11/10 at 07:30 PM Reply With Quote
Probably not going to get stuck in until new year now. got the workshop to sort out first
I'll add you to my buddy list if thats ok so I can get in touch
Thanks again
TrollyJack
posted on 19/11/10 at 09:07 PM Reply With Quote
The book bottom wishbone design has major issues
panichat
posted on 20/11/10 at 11:37 AM Reply With Quote
found them
They are unused, but have been sat in the shed for 5 years.
£12 posted if you are interested.
Image deleted by ownerDave
Trollyjack
posted on 20/11/10 at 02:51 PM Reply With Quote
Yes I'll have them
Do you have a paypal account or I will send you a cheque
Please email me yor details
My email is straw@dsl.pipex.com
TrollyJack
Trollyjack
posted on 20/11/10 at 02:56 PM Reply With Quote
What are the issues
It came with top and bottom wish bones already made
I may heve to make new ones if they are wrong
TrollyJack
posted on 21/11/10 at 05:05 PM Reply With Quote
Lower wishbone break due design fault stress raiser subject to a large bending moment --- do a search.
Best advice is either buy wishbones or a pre-cut whishbone bottom plate kit ---- Maxi ball joints allow a much better neater design.
Trollyjack
posted on 26/11/10 at 08:08 PM Reply With Quote
What about the top ones
Is the off set wrong in the book its 11mm
TrollyJack
