Author: Subject: rear caliper troubles
Crazy Jay
posted on 18/6/04 at 10:12 AM Reply With Quote
Hey, i got cosworth and xr4x4 rear calipers but none of them will fit the adaptor plate that i got from GTS. Maybe i hav it wrong but are the calipers not supposed to bolt directly onto the plate?? Cause mine are about 15mm out. Cheers
Wadders
posted on 18/6/04 at 10:53 AM Reply With Quote
would it not be a good idea to phone gts?
i]Originally posted by Crazy Jay
Crazy Jay
posted on 18/6/04 at 11:09 AM Reply With Quote
Sounds like a good idea
posted on 18/6/04 at 03:58 PM Reply With Quote
Sounds like you got rear setup for drums not discs...
craig1410
posted on 19/6/04 at 07:04 PM Reply With Quote
Have you got the caliper to hub mounting bracket from the donor vehicle? The caliper usually mounts to an intermediate bracket via some sliding guides which are essential on a single piston caliper (assuming the 4x4 calipers are the same as my standard Sierra ones). The intermediate bracket then mounts to the hub carrier. I'd expect that the GTS brackets are designed to take the place of the hub carrier and thus you will still need the intermediate bracket.
Here is a photo of my intermediate brackets:
Hope this helps,
Craig.
craig1410
posted on 19/6/04 at 07:06 PM Reply With Quote
...and here is a photo showing it all bolted together.
Craig.
Crazy Jay
posted on 23/6/04 at 12:27 PM Reply With Quote
Thanx! thats exactly wat i needed. Got the old calipers of a granada and noticed that bit. So im gettin the disc uprights soon. Cheers every1
(oh im gettin my chromed wishbones either today or tomoro )
