Author: Subject: Brake feel
posted on 19/6/04 at 09:04 PM Reply With Quote
Brake feel
I have an interesting problem - I've just fitted some new flexible brake hoses and bled the whole system with an Eezy-bleed until all the bubbles were gone (as in the instructions)
Trouble is, I can't remember the last time I drove a car without a servo (at least 30 years ago!) and can't remember how it should feel!
At the moment I can push the pedal and get a progressively stronger resistance - it's not immediately 'solid'. It's not spongy, but I am able to push the pedal more than I expected. I can't 'pump it up' - it's the same feel every time I push.
I took it up the drive and whizzed back, stomping on the brakes, and locked everything up (FUN! ) so they do seem to be working.
So... and clues, anyone? Or should I find someone with a Mk2 Escort and compare?
David (aka Puzzled of Bentley)
BTW: The engine makes a lovely noise when I zoom up and down the drive!
posted on 19/6/04 at 09:14 PM Reply With Quote
sounds right to me. Long drive, david?
pbura
Doesn't sound bad at all!
If you've got nylon/rubber hoses, they'll pump up a little bit. Perfectly normal.
That's one sharp car, btw, David!
Pete
Pete
mangogrooveworkshop
posted on 19/6/04 at 10:50 PM Reply With Quote
get hold of an old beetle and that should show you how good your brakes really are. Very tidy book car by the way.
Fozzie
posted on 19/6/04 at 11:35 PM Reply With Quote
David,
Sounds right to me too!
Have fun!
ATB fozzie
posted on 20/6/04 at 06:35 AM Reply With Quote
Well, I did use a bit of the road...
25 yard journey, there and back - but I had to accelerate energetically to test the brakes properly, didn't I?
(Still feels weird, driving it around after all these years...)
[Edited on 20/6/04 by David Jenkins]
posted on 20/6/04 at 06:37 AM Reply With Quote
They're teflon/stainless braided ones...
Thanks!
posted on 20/6/04 at 07:05 AM Reply With Quote
A car without a servo will have less pedal lost motion than one with a servo -- but drum brakes have more lost motion and are not anything like as stiff as disc brakes.
Type of flexi hoses make very little difference to pedal feel on a car with drum brakes -- the ammount of lost motion and distortion within the drum and shoes far exceeds the the elastic expansion of a fabric/rubber hose.
You need some play for the drums to work but causes of lost motion that you can do something about are
(1) Shoes and pads need to beded in.
(2) Self adjuster in rear drums need tweaking --- also check the handbrake cable isn't too tight.
(3) Pedal box flexing excessively ---- very common on kit cars gives a springy pedal
(4) Air -- the ezy bleed is a good tool but it is impossible to bleed brakes single handed even using an ezybleed as it won't get all the air out of the master cylinder without depressing the pedal 3 or 4 times.
(5) One other cause is a stuck caliper piston or pad -- the car will initially stop normally but as the pads wear the pedal will become progressively softer -- was commom on 70s Fords when new.
(6) similar to (5) on cars with rear disc brake conversions excessive pedal travel is often caused by the calipers not being in perfect alignment with the disc, tweaking the brackets by very slight bending usually fixes this.
To trace excessive travel thought to one particular wheel it is useful to clamp the (fabric/rubber) flex hose to each wheel in turn.
[Edited on 20/6/04 by britishtrident]
posted on 21/6/04 at 08:36 AM Reply With Quote
Everything on mine is brand new so that certainly needs doing!
Too tight? or too slack? Mine was certainly slack, which means that the non-piston ends of the shoes were too far away from the drum (haven't tried it since re-adjusting the handbrake).
Something to check... although my pedal box is very solid!
Not 100% sure I've got the bleeding done properly, yet... Next weekend's job!
Think I'm all right here.
Again - think I'm OK here.
Can't clamp these hoses! (but you did say rubber hoses).
Thanks BT - plenty to think about...
rgds,
posted on 21/6/04 at 10:34 AM Reply With Quote
Pedal ratio.
The pedal ratio can make a lot of difference to the feel and the effort needed. You can get to a point where you are fully braked but can still exert more pressure on the pedal but not achieve anything by doing it apart from flex the cylinder mounts.
Rob Lane
posted on 21/6/04 at 10:51 AM Reply With Quote
Concur with Pete. More than anything that affects the brakes (when working!) is the pedal ratio.
I made my original pedal box and always had solid brakes which took some effort to use. Then I modded pedal and increased ratio. Result, more travel but easier action braking.
As now I have a floor mounted pedal box with bias bar. The brakes are OK but I would prefer them easier on the leg. However, lengthening the pedal would necessitate lifting leg up under scuttle to apply brakes!! There's really no room for a mod.
Rob Lane
www.robs7.com
posted on 21/6/04 at 11:21 AM Reply With Quote
I'm fairly confident that my pedal ratio is OK - I've used the original Escort pedals. I've also reproduced the layout of the original pedal box, so the geometry should also be OK.
I'll try some of the other options discussed earlier before I worry about ratios, etc.
cheers,
Rob Lane
posted on 21/6/04 at 12:27 PM Reply With Quote
Pedal ratio is OK then.
Unservoed brakes do get a bit of getting used to. Especially if you drive a servoed car in between.
I drive a Fiesta Diesel van daily and that has a lot of servo assistance so it tends to spoil me for first few miles when I get in Locost.
Pics of car look good! SVA soon?
posted on 22/6/04 at 03:05 PM Reply With Quote
I think I may have identified my problem... in my wisdom, I used Automec DOT 5 silicone brake fluid instead of regular stuff. After doing a major web search, it seems that a significant usability problem with this stuff is a spongy brake pedal. The main reason for this is that the fluid holds air within its molecular structure far more than glycol fluids.
This can be largely avoided by (a) gently pouring the fluid into the master cylinder and letting it stand for 10 minutes before starting to bleed the system, and (b) NOT using an Eezi-bleed, which has air at 20psi over the top of the fuid in the reservoir, and splashes the fluid when it tops up the level!
Item (b) explains why my system felt more spongy after changing the flexible hoses - the first time I bled the brakes I used a 1-way valve bleed tool, but the second time I used the eezi-bleed.
I still intend to use the DOT 5 fluid as it's benefits suit my use of the car (a couple of thousand miles/year doesn't keep glycol fluids up to spec), but it looks like I need a different bleeding technique... (read those last few words in whichever way you like! )
Second attempt this coming weekend...
timf
posted on 23/6/04 at 07:23 AM Reply With Quote
my instructions for my old eezi bleed says use 2-3 psi not 20
posted on 23/6/04 at 07:33 AM Reply With Quote
Mine's fairly new, and the instructions say 15 - 20 psi (lower for Fiats, which have a weak master cylinder reservoir!)
