daniel mason
| posted on 29/11/10 at 08:29 PM |
fixing copper brake lines to braided lines
it there a brake pipe fitting for conecting the copper brake lines in the mnr to the mounting brackets on the chassis? if you connect them directly to
the braided lines there is plenty of play in the joint as it does not make contact with the bracket. cheers. i will try to find a pic to explain
better.
| posted on 29/11/10 at 08:36 PM |
You should have a 1/4 height nut fitted to clamp to the end of the hose end to the bracket before you fit the pipe.
daniel mason
| posted on 29/11/10 at 08:40 PM |
the brake lines are pre made and flared, there is a nut on the end but even when fastened tight to the thread on the flexi pipes they dont tighten up
to the bracket. if that makes sense, (as though the threads are too long on the flexi pipes)
blakep82
| posted on 29/11/10 at 08:45 PM |
nope, thats coorect, then as said above you have a small nut which tightens the flexi pipe to the bracket, and holds that secure, then the copper pipe
screws on to the remaining thread on the flexi pipe
like this
red is the flexi with male thread in yellow, grey is the bracket, brown is the thin brass nut, yellow is the remaining thread, and copper colour is
the copper pipe
[Edited on 29/11/10 by blakep82]
________________________
daniel mason
| posted on 29/11/10 at 08:48 PM |
i see now. the nut goes on the inside of the bracket and secures the flexi. then the copper screws into this. thanks
