Author: Subject: brake pipe fitting thread sze
daniel mason
posted on 7/12/10 at 02:23 PM Reply With Quote
i need 4x nuts to fix my flexible brake lines to the brackets on my chassis, i am not with the car at the moment so does anyone know thread size? goodridge hoses for mnr vortx. cheers
[Edited on 7/12/10 by daniel mason]
Mal
posted on 7/12/10 at 05:26 PM Reply With Quote
Probably M10 x 1 - a fine pitch thread.
daniel mason
posted on 7/12/10 at 07:12 PM Reply With Quote
cheers mate
adithorp
posted on 7/12/10 at 09:37 PM Reply With Quote
If it's half-nuts (only thin) you want then they might be tricky to find. As an alternative in the past I've taken female brake pipe nuts and cut a slice off to form a half-nut.
http://jpsc.org.uk/forum/
daniel mason
posted on 7/12/10 at 09:58 PM Reply With Quote
thanks for the heads up adrian, i will check my fittings this weekend!!!
