Author: Subject: Bracket location/ caster camber set up help
KECHICHE
posted on 13/12/10 at 11:38 AM Reply With Quote
Hi there i need some help here if anyboady could pls
bought a chassis based on a locost without wihbones brackets,
so when i got to weld them i thought about the caster and camber dont know what degree the wishbones should be set at & no info in the haynes roadster book about cater.
ps- only using independent at the front gone for live axle at the back.
hope that helps thanks Alex
pls advise
Amateur builder my first project
prawnabie
posted on 13/12/10 at 11:48 AM Reply With Quote
The Haynes books applies to cars using IRS on the back end and sierra front uprights - if you have bought a locost with a live axle I would use uncle rons book. I have a copy you can have for a tenner inc post.
[Edited on 13/12/10 by prawnabie]
BillHoll
posted on 13/12/10 at 12:44 PM Reply With Quote
Look under 'info' in my photo archive and there is a drawing for setting up the front suspension brackets. Ignore the top shock absorber bracket as this is for longer shock absorbers.
[Edited on 13/12/10 by BillHoll]
[Edited on 14/12/10 by BillHoll]
mistergrumpy
posted on 13/12/10 at 01:01 PM Reply With Quote
Borrowed from James's archive. What I used on my Locost.
The plans
The plans
KECHICHE
posted on 13/12/10 at 09:29 PM Reply With Quote
hi guys realy appreciate your help so happy that will make my job much easier,
thanks and happy christmas
procomp
posted on 14/12/10 at 10:16 PM Reply With Quote
Hi
Only tack weld the brackets to the chassis. Then assemble your uprights wishbones etc etc and measure the Castor you have. You want a min of 5 Deg Check by measuring the correct way of turning the wheels not by simply measuring the angle difference calculated by bracket position.
Cheers Matt
