phelpsa
posted on 22/6/04 at 03:22 PM |
Princess 4-pots
Anyone else using princess 4-pots? How have you connected the two holes together input holes together in the top?
Adam
ned
posted on 22/6/04 at 03:35 PM |
stevem is running princess 4 pots on the road. i think he linked a t piece in with copper piping, try u2u/emailing him to be sure..
Ned.
beware, I've got yellow skin
phelpsa
posted on 22/6/04 at 03:36 PM |
Thanks ned, will do.
Adam
GasGasGas
posted on 22/6/04 at 04:13 PM |
Two into One will go
You have to fabricate a link pipe from the first side bleed nipple outlet to the second hose inlet to bridge the caliper and bleed only from the
outboard side of the caliper. Thats how its been done on the coversions i've seen.
phelpsa
posted on 22/6/04 at 04:26 PM |
Do you have any pictures GasGasGas.
Adam
phelpsa
posted on 22/6/04 at 04:40 PM |
http://www.dominicbolton.freeuk.com/brakes.html
Just found this site, says a t-piece going into the two inlet holes is better but because the escort only has one pipe a lot of people do as you
described.
Adam
