The Venom Project
posted on 24/12/10 at 02:02 PM |
Brake 4 and 3 way leaking issues, how do i stop the leaks?
Hi All,
After a problem on my MNR in April with brake fluid leaking at the 4 way and 3 way brass joints, I wondered what other people were doing to combat
this?
I had thought initially it was my flare tool, but even when MNR had made the pipes up, they still leaked.
I ask because come the new year, I will hopefully be starting a build again and will no doubt come across the issue again.
I thought they were not tight, but after stripping the brass thread with making them as tight as possible and it still leaking I was unsure what to do
next.
Does it matter if you use Metric over Imperial brass fittings? I wasn't sure that the plated unions were good enough? Wasn't sure if
they were seating correctly either. Does anyone use Gas tape to seal them? or any other type of sealing method?
Any help would be most appreciated
Merry Xmas to all
Nick
It's not that i'm lazy, it's that I just don't care.....
mistergrumpy
posted on 24/12/10 at 02:09 PM |
I've used PTFE on a couple of my joints and had no issues. CKC recommend PTFE too but a few on here won't agree. Their take is find the
fault and fix it, which I think is easily said than done when you chase it for months and months on end.
You're probably aware that there are differnt grades of PTFE but most are unrective.
I'm sure I'll get flamed for writing this!
The Venom Project
posted on 24/12/10 at 02:12 PM |
To be honest, I saw no other way of stopping the leaks. I didn't get chance to use this method as my car died on the rolling road, maybe that
was a good thing eh?
Cheers, I will of course try the old method on the new kit, but I reckon ~PTFE or something similar may have to be used, because if you have it as
tight as it can be, how do you stop it leaking?
Many Thanks
Alan B
posted on 24/12/10 at 02:17 PM |
No flames...but PTFE tape (or sealant) is for taper threads only...where the sealing is actually done by the threads (sometimes there are taper
threads in brake systems, but not often)....parallel threaded fittings do not seal on the threads and should never be used with tape.
As much a pain as it is, you really should fix the problem...not do a tape bodge...
Just my opinion of course..
Happy Christmas everyone
The Venom Project
posted on 24/12/10 at 02:22 PM |
If you make everything so tight that it strips the thread, and it still leaks, what is the solution?
I have thought I may invest in a Venhill braided hose and cable kit instead of brake pipe, and use alternative fittings in that kit?
I am quite clearly not the only person with this issue, whether its a crappy Brass cast who knows. What do you use in the USA on Kits? What have you
used on that car in your pic?
Does it weap? or leak at all?
Nick
daviep
posted on 24/12/10 at 02:26 PM |
Where exactly do you even put PTFE tape on a flared connection? I can't believe that CKC would recommend using PTFE if it's picked up at
an MOT it's a definite fail.
As per the last time you aked this question please try and get some detailed pictures of all the components so that informed diagnosis can be made.
Davie
The Venom Project
posted on 24/12/10 at 02:27 PM |
Davie
Cheers Davie,
Well I will post pics if I encounter this issue again, does everyone still use the 3 and 4 way Brass units for brakes?
Is there not something nicer to use on the market?
Nick
daviep
posted on 24/12/10 at 02:29 PM |
How tight did you make the unions when you first tightened them?
They don't really need to be very tight and if overtightened can distort causing them to leak, only remedy is to cut off and re flare.
Davie
The Venom Project
posted on 24/12/10 at 02:33 PM |
Brass vs Plated union
Just looking for alternatives to plated connections, I see they do make Brass ones, do you think this is a better idea instead of Plated ones?
I would have thought brass to brass might be a better idea?
I appreciate say that PTFE is not the cure, but if you have checked everything and even the manufacturer can't stop the leak, where are you
meant to go?
Nick
P.S I will post pics if it does it again, but I may go down the Brass all round way as the other way first time round was not a solution
prawnabie
posted on 24/12/10 at 02:35 PM |
If it is happening on all the connections to the unions are you sure you haven't mixed 3/8 and 10mm fittings?
The Venom Project
Davie
Initially they were nipped up with the ring spanner, it was only when I came to bleed them did I see an issue, on all points front and back.
I started at the back, and the pipe coming down into the 3 way I made tighter and tighter until it stripped.
I know MNR still had issues with this as it went to the rolling road, I am not sure how they fixed it, however I could ask Indybird what he found when
it was stripped down.
CHeers
Nick
RichardK
posted on 24/12/10 at 02:38 PM |
I reckon you've done them too tight, I did all mine handtight then about half a turn with 1/8 further turns until they stop seeping if
necessary. Which are leaking the bullet shaped end or the double flared end?
Rich
Gallery updated 11/01/2011
The Venom Project
I had a nasty feeling about that initially, but then when MNR still had the same issue, I assumed this was not it.
From past experience, I never had any type of issue like this on old cars, I was very upset that each point bloody leaked :-)
The Venom Project
posted on 24/12/10 at 02:39 PM |
Rich
They were all bullet shaped ones, all the points into the brass ports. The double flared ends were fine :-)
RichardK
posted on 24/12/10 at 02:44 PM |
Strange, I found those the easiest to do, I'd make sure that there isnt a ridge caused by the two halves, if so, run a fine file over to remove
the ridge. and then I smear a tiny bit of coppaslip on the back of the neck of the flareso the fitting slides around it a bit easier while
tightening.
Hope you get it sorted mate.
Rich
posted on 24/12/10 at 02:49 PM |
Sounds like the wrong flare / pipe nut or union . In 43 years in the motor trade I can honestly say that I have never had a leak on a correctly made
union. PTFE tape is a bodge and should fail an MOT . Was a metric flare used or an imperial?? as the flares are a different shape. A UNF fitting is
slightly smaller than a metric one and may be the cause of your problem?
The Venom Project
posted on 24/12/10 at 02:53 PM |
Many Thanks,
I think I may have them all professionally made by my local garage for my next build.
That way, they will get the right pipe size, right flare, right end, I reckon I am onto a winner
If I just measure what I need, hopefully I can't lose if I take the 3 and 4 way units to him.
Nick
whitestu
posted on 24/12/10 at 03:00 PM |
I'm surprised - I made all my pipes with a cheap crappy Machine Mart tool and only had one leak which was fine when I redid it, and if I'm
honest I'm not very good at doing them.
Are you sure the parts you are using are all the same?
Stu
The Venom Project
posted on 24/12/10 at 03:04 PM |
Leaky Leaky
Hiya,
I must stress, this was an issue with my MNR, but I look forward to new things with my TR1KE, I may never encounter this issue again.
I can't say for sure all the bits were correct when I did it, but when it was re-done at MNR it still leaked.
However I think in light of the fact I had this issue, I will indeed get my local garage to make them, I too bought a cheapish tool after I had the
issues, but initially I used a very expensive SIP brake pipe making tool, that I had used when I worked in the motor trade back in 1990, and never had
issues back then,
Anyway, I hope this issue doesn't arise with my new build
If so, I will be back on with leaky leaky pics
Nick
big_wasa
posted on 24/12/10 at 03:19 PM |
I bought the best tool I could aford and none have leaked.
posted on 24/12/10 at 03:57 PM |
Make the flares properly and use the correct tube nuts with the correct length of thread ..
[Edited on 24/12/10 by britishtrident]
gavin174
posted on 24/12/10 at 04:02 PM |
contact Russ Bost
he can make complete brake lines with stainless fittings..
http://www.furoreproducts.co.uk/7_hel
The Venom Project
posted on 24/12/10 at 04:04 PM |
quote: Originally posted by gavin174
contact Russ Bost
Many Thanks,
I will contact him in the new year and discuss prices.
Nick
ashg
posted on 24/12/10 at 04:32 PM |
could possibly be crap t fittings. I had a similar issue on a 3 way one, eventually used the 20year old one the was off the sierra and the problem
went away.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 24/12/10 at 08:10 PM |
went away.
Ford use short tube nuts the after market type require tube nuts with a different end and a longer thread these are used by many other
manufacturers including Vauxhall/Opel.
