goodguydrew
| posted on 30/12/10 at 11:31 AM |
Caliper rebuild question
Hi all,
I am about to rebuild my Cortina calipers,
Should I lubricate the O-ring that goes between the caliper halfs, or does it go in dry? If so, do I use clean brake fluid?
Any other tips welcomed.
Thanks.
[Edited on 30/12/10 by goodguydrew]
Bluemoon
| posted on 30/12/10 at 11:32 AM |
I used clean break fluid.. You can I believe get proper rubber grease for this (red stuff I think)..
Dan
mookaloid
| posted on 30/12/10 at 11:45 AM |
I use a light smear of red brake grease - always gets things running smoothly
cliftyhanger
| posted on 30/12/10 at 12:19 PM |
but NEVER EVER any copper grease, or any other sort of grease.
Red grease excellent, but I would just use brake fluid for the o ring as it doesn't actually move, just needs seating.
goodguydrew
| posted on 30/12/10 at 03:51 PM |
Thanks for the advice.
