chris666
posted on 3/1/11 at 08:15 PM |
sump clearence
Whats the minimum clearence from sump to floor on a zetec black top ppl would recomend?And whats the best solution to get more clearence if needed.Ive
alredy a shortend sump fitted.my clearence is 2"floor to sump.
Cheers Chris
speedyxjs
posted on 3/1/11 at 08:35 PM |
I thought mine was low at 3". I think most run about 4"
chris666
posted on 3/1/11 at 08:46 PM |
oh dear.
ianclark1275
posted on 3/1/11 at 09:10 PM |
ive asked before and i recall people advising if you can run over a house brick, you will be fine.
2.5 inch .
but that is low.
measure twice, cut once, scrap it, start again.
RichardK
posted on 3/1/11 at 09:20 PM |
2" is too low mate, are your tyres pumped up to the right pressure and shockers set up right mate? Around my neck of the wood with speed humps
I need all of my 4"'s.
Rich
Gallery updated 11/01/2011
plentywahalla
posted on 3/1/11 at 09:26 PM |
The max legal height for speed bumps is 100mm or 4".... so that should be minimum for clearance.
[Edited on 3/1/11 by plentywahalla]
Bluemoon
posted on 4/1/11 at 09:31 AM |
And that normally means chopping the sump level with the bell-housing to keep the engine low in the bay. I have yet to chop the sump and are close to
100mm so jacked the suspension up a little, this is not ideal! Sounds like you will need to get the sump chopped..
