Author: Subject: Cortina Upright taper dimensions
phelpsa
posted on 6/1/11 at 12:40 AM Reply With Quote
Does anyone know them?
I could measure but not particularly accurately.
Cheers, Adam
phelpsa
posted on 6/1/11 at 12:46 AM Reply With Quote
WOW I actually got the search function to work!
Seems to say 8:1 taper is standard for ford. Can anyone confirm this?
Doctor Derek Doctors
posted on 6/1/11 at 09:47 PM Reply With Quote
I was just searching google for the exact same data and ended up back here.
I'm actually trying to work out how to fit a Lower front wishbone with a 5/8" UNF rod end to a Cortina upright by using some sort of tapered insert.
Does anyone sell such a thing (or similar) or have a drawing to make one up?
phelpsa
posted on 6/1/11 at 10:03 PM Reply With Quote
I'll draw one up in a bit. It'll be to use a 1/2" bore rod end but you can get 1/2"x5/8" rod ends quite cheaply.
