Author: Subject: Diff and drive shafts
neilp1
posted on 11/1/11 at 03:55 PM Reply With Quote
Well after a sh*t day finishing stripping the sierra, it has gone from bad to worse. I stripped the back end (diff drive shafts) only to find out that the diff is actually a 7.5" diff and wont fit my avon chassis. I'm not prepared to alter the chassis as it is powder coated.
What are my options, can I buy a 7" diff and still use the drive shafts from the 7.5" diff or are they different lengths?
loggyboy
posted on 11/1/11 at 04:12 PM Reply With Quote
Didnt think sierras had 7.5 inchers, only granads and cossies?
mcerd1
posted on 11/1/11 at 04:47 PM Reply With Quote
sorry don't know about the shaft lengths - but I have got a spare set from granda with 7" diff (bolt-on type and they are missing 2 of the CV's)
sierra's can have them too
mostly in later models, alot of the DOHC sierra's have 7.5" diff.....
posted on 11/1/11 at 05:03 PM Reply With Quote
I have spare 7" drive shafts, I'll bring them across and see if they fit.
big_wasa
posted on 11/1/11 at 06:08 PM Reply With Quote
Yes the last of the Twink sierras where fitted with a 7 1/2" diff in both Lobro and push in.
Ive measured them as being the same width so if the splines are the same they should work.
neilp1
posted on 11/1/11 at 07:47 PM Reply With Quote
As in splines do you mean on the push in shaft? I have the bolt on type.
mcerd1
posted on 13/1/11 at 07:15 PM Reply With Quote
in that case don't worry about the splines - measure the outside diamiter of the CV joint instead
as long as they are the smaller size on the diff you've got now then they are the same as the 7" ones (most 7.5" diffs have the same size as the 7" )
i'll check the size of mine later on to compare them
[Edited on 13/1/2011 by mcerd1]
