Author: Subject: Wrong wheel nuts?
stevegough
posted on 11/1/11 at 08:00 PM Reply With Quote
Wrong wheel nuts?
During my recent IVA test, the tester advised me that the wheelnuts I was using, whilst secure, were incorrect for the alloys I have fitted. They have integral captive cup washers which can still be turned even though the nuts are tight. On closer inspection, the seat in the alloys is almost flat, with a bevel in the centre only - it is this bevel that the nuts are tight against. Anyone any ideas what I need to order to replace them? -
I will go and take a couple of photos to better illustrate the problem.....
[Edited on 11/1/11 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
paulf
posted on 11/1/11 at 08:51 PM Reply With Quote
They look as if they should have sleeve type nuts with a parallel spigot and a flat washer, there a various sizes available so you would need to measure the bore of the wheel around the stud.Those nuts are the ford alloy wheel type.
Paul
