Author: Subject: CAST IRON
johnq
posted on 12/1/11 at 11:48 AM Reply With Quote
CAST IRON
Hi all ,just snapped a casting on my pillar drill, any ideas on a repair plan , can cast be welded brazed etc, thanks in advance,john
looks like rain again
JAG
posted on 12/1/11 at 12:23 PM Reply With Quote
It can be welded but is VERY specialised work.
There may be someone on here??? You never know
Justin
blakep82
posted on 12/1/11 at 12:26 PM Reply With Quote
as far as i know it has to be heated and arc welded? in fact www.mig-welding.co.uk has something about it i think
http://www.mig-welding.co.uk/welding-cast-iron.htm
[Edited on 12/1/11 by blakep82]
________________________
posted on 12/1/11 at 12:36 PM Reply With Quote
Brazing or silver-soldering would be the easiest, as long as it would be strong enough. It does work well, as long as the surfaces are really clean. Trouble is that you'll have to get the whole piece up to red hot to make the join!
Welding is difficult, IIRC. You will probably have to heat up the whole piece before welding, otherwise the localised shrinking around the weld will just break the iron somewhere else nearby. I'm sure that someone else on here will know more than me though (not too hard...)
martyn1137
posted on 12/1/11 at 01:29 PM Reply With Quote
If parts are very clean and have relatively large contact area you may get a better result using epoxy resin glues. Eg Araldite types.
Any repair is going to risk future failure on cast iron I am afraid.
posted on 12/1/11 at 03:02 PM Reply With Quote
I've successfully MIG'd a couple of cast iron exhaust manifolds with normal mild steel wire, by heating the whole thing in the oven (wife got a bit upset!) then getting the area around joint as hot as I could with a blow lamp prior to welding and kept playing the blow lamp over the joint afterwards to let it cool as slowly as possible. Both manifolds are in daily use 3-4 years later with no leaks. Not sure this would be possible if good dimensional accuracy is needed on the welded part though.
[Edited on 12/1/11 by MikeRJ]
Bluemoon
posted on 12/1/11 at 03:28 PM Reply With Quote
Photos might help.. what part have you broken? Simple repair might be possible not tried it but epoxy and some "fish plates" (i.e .bolted re-enforcement plates might help? depends where the break is..
Dan
posted on 12/1/11 at 03:53 PM Reply With Quote
Dan
Or steel dowels through the piece?
