Author: Subject: Front wheel alignment
Trev Borg
posted on 29/6/04 at 10:42 PM Reply With Quote
Ok, firstly the car is an autotune gemini not a locost (but still cheap)
With the steering wheel central both wheels are parallel and pointing forwards.
At full lock either way the outside wheel turns tighter than the inside wheel.
I thought this should be the other way round. I thought the inside wheel should turn tighter ?
The steering rack is a shortened escort with cortina uprights, the rack sits forward of the upright joints.
Any advise welcome
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
Trev Borg
posted on 29/6/04 at 10:44 PM Reply With Quote
oh, also full lock is very very tight in guess about 65 degrees (never measured)
when turning the car tight tyres skip !
pbura
posted on 30/6/04 at 12:52 AM Reply With Quote
By any chance, is your rack in front of the steering arms? I think this could make for a negative "fake Ackermann" effect.
The Gemini looks like a good pick
Pete
Pete
Trev Borg
posted on 30/6/04 at 02:09 PM Reply With Quote
The rack sits 2" forward of the steering arms.
The gemini chassis that i bought half built, already had the rack fitted on the chassis brackets, but I can't see any reason why I can't move the rack further back.
I assume that this is what I need to do is it ?
Am I right in thinking that it would be better if the they were in line ?
crbrlfrost
posted on 30/6/04 at 03:21 PM Reply With Quote
Ackerman has to do with the orientation of the steering arms on the uprights. With reverse ackerman, the angles are probably divergent when viewed from the top. With typical ackerman, the steering arms point inward toward rear axle center, and this helps set up the geometry. Speaking of ackerman though, reverse ackerman is not "fake ackerman" as it is used on formula one cars depending on the designer, just as positive caster had been used during the skirts and venturi pods era. Cheers!
NS Dev
posted on 30/6/04 at 06:00 PM Reply With Quote
Yes, you need to move the rack back, preferably so the centreline is slightly (0-1"as a guess) to the rear of the steering arm ends on the uprights when they are straight ahead
Trev Borg
posted on 30/6/04 at 07:34 PM Reply With Quote
I've ben reading a lot of stuff on steering and i think you're right, the only confusing thing is that the chassis is bracketeed for the rack to go there.
That was until I did a bit web smurfing and came across a site for someone building one. He has a picture on his site that shows the brackets further back(just where you said)
I've e-mailed him, and am wauting for a reply, but it looks like problem solved.
I had contacted Autotune firstly but was just told the the steering would need setting up properly. I may give them a ring in the morning and ask them where its suppossed to be.
Thanks for the help guys
