New Topic New Reply
Author: Subject: Indy dog leg steering link
bob
posted on 28/1/11 at 07:33 PM Reply With Quote
Anyone with an Indy running a zetec found a good solution to avoid the oil filter using a dog leg steering link.
I've been using the small renault 5 turbo filter for the last 4 years and it works JUST, i've noticed with a bit of movement on the engine mounts the shaft does actually touch the filter as the paint has worn away. I'm thinking a better solution to this would be dog leg (uj) in the shaft and know its been done, i just need some info/pics of anyones work for ideas.
Any help with this appreciated.
big_wasa
posted on 28/1/11 at 07:38 PM Reply With Quote
or a remote filter ?
bob
posted on 28/1/11 at 07:46 PM Reply With Quote
Hi warren
I've tried the remote for size and and its very close to the renault filter size, i will have a look at robocogs set up as i'm sure he runs a remote. I just think a dog leg would be a better fix, not only for the shaft against filter but for access to the filter when i change it.
It might even be a case of my engine on the mounts is too central as i did read a lot of zetec runners push the engine over a touch.
lotusmadandy
posted on 28/1/11 at 08:04 PM Reply With Quote
Hi Bob,
I fitted an extra uj in my Indy column,when i swapped to a zetec.
I now use a filter from a fiesta zetec and could actually fit a full size
mondeo filter.
I bought my shaft and u/j from MNR,though they were not cheap,they are top
quality items.
I will take some pics in the morning if you need them.
whitestu
posted on 28/1/11 at 08:53 PM Reply With Quote
The other option [which is probably more difficult] is to cant the engine over a bit by modifying the engine mounts.
stu
L5W
posted on 28/1/11 at 09:07 PM Reply With Quote
I found on my MK chassis that with the mounts that came with the kit, even a remote connection to the oil pump wouldn't have cleared the column link section. Here's my solution, perhaps not the best way but seems to work
I got the extra U/Js from CBS, a length of hex from ebay and the rod end bearing came from http://www.bearingboys.co.uk/
Lee
http://l5w-mk-indy-zetec.blogspot.com/
jonesier1
posted on 28/1/11 at 09:52 PM Reply With Quote
have a look at some avon's,thats where i got my dog leg idea from to clear my zetec engine.its close but works,just welded a support for the shaft from the chassis.
im in my own little world...its ok though they know me there
bob
posted on 28/1/11 at 11:12 PM Reply With Quote
Originally posted by lotusmadandy
Hi Bob,
mondeo filter.
quality items.
Thanks Andy pics would be great, i'm ok with the cost as i havnt spent a bean on my indy for nearly 3 years which pleases me a lot (and mrs bob)
Thanks everyone for your input.
graememk
posted on 29/1/11 at 09:15 AM Reply With Quote
i have that prob too thanks for the pics
lotusmadandy
posted on 30/1/11 at 09:00 AM Reply With Quote
I will post some photos shortly.
lotusmadandy
posted on 30/1/11 at 11:57 AM Reply With Quote
I have uploaded some photos to my archive but cant seem to remember
how to post them atm.
bob
posted on 30/1/11 at 04:22 PM Reply With Quote
Andy thats a great big thanks from me for the pics, exactly what i had in my head but just needed confimation that somebody else had actually achieved this.
Lee thats fine, as long as it works mate. I've seen that set up before on a couple of other cars on my travels.
I now have the extra UJ and length of bar to link the rack to the UJ so i just need the spherical bearing for whatever size bar i use on the modded link from column to the UJ.
I'll let you know of the progress.
I'm sure one of my local nice friendly locosters will weld up my creation for tea and biscuits.
DavidW
posted on 8/2/11 at 10:49 PM Reply With Quote
I tilted the engine slightly (plate under the passenger side engine mount) and it let me get the remote filter head on with just enough clearance.
New Topic New Reply
