GBaggott
| posted on 1/2/11 at 01:28 PM |
Raceleda uprights with raceleda calipers - 2mm pad overhang.
Hi
I currently have racveleda uprights with raceleda 4 pots, but there is a 2mm pad over hang on a 247mm diameter cortina solid disc.
I have run it like this for 3 years no big deal, but am now looking to upgrade to hi spec either lug mounted or ideally radial mounted with 280mm
discs.
Does any body know where to buy different brackets that bolt on the raceleda uprights?
Can you get a 252mm diameter solid (none vented 9mm thick) cortina disc?
Advice links would be much
Thanks Gareth
big_l
| posted on 1/2/11 at 02:02 PM |
Try calling Chris @ mnr racing they bought raceleda out when they went bust !!!
Check out my blog mnrvortxhayabusa@blogspot.com
phelpsa
| posted on 1/2/11 at 02:39 PM |
quote: Originally posted by GBaggott
Hi
discs.
Thanks Gareth
The only discs that are that thin are the cortina/capri mk1 1300 discs, but they are only 244mm diameter IIRC. All the rest are 13mm.
